Back like a bad habit.... hope you guys don't hold anything against me... And thanks Randy for lettin me hang around some more....
This exhaust port is very oval shaped compared to others I’ve seen. The sides at the exit look straight, but inside it’s smaller and completely oval shaped. I’m not sure how much I can mess with the design, so I’ll do it in stages. This time around I’m going to mostly stick to the original port shape but just widen it, focusing more on the roof, so the roof will end up being the widest spot. I decided to use a chainsaw file.
The metal came off surprisingly easy. I knew being aluminum it would, but it went even faster than I anticipated. The thin black carbon layer in the port actually helped as a visual reference. I marked on my wooden blank where 70% of bore was. I ended up taking it to 61% and I’m thinking I may try that first before I go out to the full 70. Everything I’ve read says small changes make big differences and to be conservative. So I went about a total of 4mm. I also raised the roof a hair.
After filing I wrapped successive grits of sandpaper around the file and sanded down to 1000 grit. It went fast. Then to get the inner port bevels I took the smallest diameter chain file, heated it up, bent it, reheated and quenched in water to regain the temper. This worked very well (I’ll refine and smooth the end for next time to avoid any scratching of the cylinder, maybe even put something on it, but I was extra careful).
I then cleaned up the bevels with some fine grit sandpaper. I read also that these bevels shouldn’t be big at all and most of the bevel needs to be at the top arch of the port roof. The original ports had no bevel that I could see. The intake port even seemed to have a ragged sharp edge. I lightly cleaned up all the bevels. Second to last pic shows port. It’s upside down, so the wider part is actually the top.
