Something does not add up. If the squish is .065, compression s/b low, and saw should be easy to pull over.
Make sure you don't have flooding in the crankcase, that will make it impossible to start, and very hard to pull over.
Pull the plug, move the piston to BDC, rotate the saw (slowly) 180 degrees, if there is fluid in the crank case it should spill out. (If the lever in the carb is set too high, this will happen).
Next, (as previously mentioned), make sure the controls are operating the carb properly. Pull the air filter, move the control lever all the way down, the choke s/b closed. Move the control lever up one (high idle), the choke should open and the throttle s/b part open. Then move one up again, and throttle s/b closed (for idle). Then pull the trigger and make sure the butterfly is wide open.
Also, sounds like timing not being right is a real possibility. If you are sure everything is right, maybe try a different fly wheel.
Check + or replace fuel lines + filter, and make sure the impulse line is well connected on both ends. Some of the ones that come with these kits are a little short. If it is leaking air on either connection, you will have problems.
Replace the plug, just in case.
Best of luck with it, and welcome to the site.
