- 11:03 AM
- Sep 7, 2021
- S.E. Texas
Thank you @MustangMike !
There were a few minor issues, the most notable being the lack of a throttle rod.
The chain break cover is slightly oversized. The same was true for my 440 kit.
Only one exhaust gasket, I know that OEM saws only have one but the plate on those saws is made to act as a gasket and they do. But not so much in the AM kits.
The powder coating on my case halves was really bad, chipped off very easily, which prompted the painting.
The "Air horn" or the Aluminum piece that pushes the carb against the intake boot, did not have threads in it for the air filter mount and was too large of a diameter to put 4mm threads in it. I was able to epoxy the threaded peg in place.
There was no aluminum foil sticker in the kit.
The coil lead is about 1" too long.
I really do not like the carb that comes in the kit, It was also the HlHic that was included in my 44o kit, I had to swap it out with one of my Anaba's. Both of those HlHic carbs were swap'ed out. I will investigate them to see if I can discover their issues.
I think that sums it up for the minor issues.
The Saw runs very good!
