Backtroller
- 5:57 PM
- Dec 31, 2015
- Land of Badgers
Joe's saw builds make me want to add a Echo to the list.
That would be nice. I rent them my idears...I'll get with ya sometime when I get back.Yeh, he a bad influence...
Understood. Im not a fan of a low ex. Probably from hangin around Mikey Lee for so long. Regardless, the saw looks great Joe. Props on the time and thought you have put into this one.I think it could handle 98/9 easy enough. Would rather try dropping the jug first and keep it round 101 if possible.
Where you like your 046#'s?Understood. Im not a fan of a low ex. Probably from hangin around Mikey Lee for so long. Regardless, the saw looks great Joe. Props on the time and thought you have put into this one.
If you promise to bring it back I could drop it off on your porch. But I will need it delivered before the mi gtg lol.Joe's saw builds make me want to add a Echo to the list.
LolTempting....however my yard might look pretty barren by the time you'd head back home.
So are you gonna start selling some BB kits for these saws now ........
I could back together my own muffler.
I wonder if you could rig up a die for that fancy stamping machine to save ya 10 plus hours.of welding?
Fantastic job Joe. Not sure how I missed this build till now.
I wouldn’t want to decrease case volume at all. That spacer you made increased it, which is good.
I’d also want the transfers lower. Have you plugged the numbers into Lambretta or Torquesoft to see where 125 is?
Generally want a lot more BD in a quad, but you know this already. You can go 1/2 of the ring on the ROD. The entire ring doesn’t have to be on the plating at TDC.
My understanding is that the new 501 has an unlimited coil? Might have helped us with our 490 builds. Would it fit this model?
I heard some moron was supposed to weld you up a 50mm 044 jug to try on this saw, but he welded up a 48mm 036 jug in error. What an idiot
The highest ex Ive tried in an 046 was 98-99ish. Generally 18-19 bd.Where you like your 046#'s?
Hda 268.The highest ex Ive tried in an 046 was 98-99ish. Generally 18-19 bd.
What carb are you using?
This thread tells me that I should keep this saw:
It starts and runs flawlessly -- CS-670.
Add 30% resale value?Well there you go. All it needed was a Stihl bar lol
