Wonkydonkey
Plastic member
- 1:50 AM
- May 14, 2017
- Sussex, UK.
Take a vid, and post it, then we can all hear the clock tick, but made sure you near a clock first
Does a scratch on the skirt affect longevity? Do you think the dealer did the right thing, or should they have replaced something?I tore down a new 395xp a couple of weeks ago and found a place on the intake skirt about like the one in the OP.
And.....it's one of many I've found over the years.
Just a reminder that no manufacturer is immune to assembly flaws.
I'm puttin ya on the spot. Lol
Here’s My Advice to you Sir, put your earplugs in and run that saw till something happens! “ Worry less, Work more”! Regards CatManHere's a video of the noise: First part just shows no issue with engagement. When its running you can hear the alarm clock noise I'm on about?
That’s normal sounding to me. I had a brand new echo 590 with a scratch on the piston just like your saw. It was disheartening but did not affect the saw negatively.Here's a video of the noise: First part just shows no issue with engagement. When its running you can hear the alarm clock noise I'm on about?
Hi I'm new to this forum. I just purchased a Stihl MS 261 cm yesterday and I have the exact opposite problem. Oil is leaking out of it on the chain side like an old Harley Shovelhead. When I run the saw , oil actually drips off the bottom of the handle. Also with the saw turned off, when I stand the saw on the handle and vertically with the bar pointing up in the air you can actually see the oil dripping out by the chain sides and streaming down the underside of the handle. I am using medium weight Stihl chain oil. I'm taking it back to the dealer today to see what they can do about it. I don't think the oilers on these new 261s are adjustable. I will post an update later ,good luck on on your "too little"oil issue.
It sounds like the clutch drum to me, normal, but you get what kind of Ringing sound out of it on a new saw, Well at least when they’re quiet, no muffler mod you can really hear the ringing sound of the clutch drum,See if the sound changes if you engage the chain breakHere's a video of the noise: First part just shows no issue with engagement. When its running you can hear the alarm clock noise I'm on about?
