Workshop
- 4:13 AM
- Jan 19, 2016
- Nixa, Mo.
For me, a compression gauge reading is nothing more than a test to see how well the cylinder (piston, rings, gaskets and valves, in the case of a 4 stroke) is sealing. It's used to check the mechanical condition of the engine. Where real power is generated is how well the cylinder is filled with air and fuel. However, you still have to compress it to get power out of it. So, compression readings do come in to play in as much as a higher reading can indicate a better performing engine. Volumetric efficiency is where real power comes from. An engine is basically an air pump. How well the cylinder is filled at speed determines how much power comes from it.
I'm reminded of reading a few years ago about NASCAR engines. It was stated that the static compression was about 9 or 10 to one. But at eight thousand rpms, through volumetric efficiency, the compression was equivalent to about 14 or 15 to 1.
Just my thinking on the subject, but I'm no expert.
