~WBF
Thecallofthewildanswered1989-2017[PAID IN FULL!]
I have only ever seen West Coast Fallers videos in spring of 2013 when I got a smart phone and just then learned to type at that time. That was just in a few days span and that's the last I have looked. Occasionally people post the odd thing on saw sites. Not often this kind of stuff I see.Skip the first 2 mins of the last vid, as I don’t need bbq sticks.. but a very good vid.
I’ve been watching this same guy for a while. When I get time
His name sounds familiar and his face is very familiar from somewhere??can't figure it out? I will get to see and post more of is collection on here. I see he is old skool round filer like me.
The spiral grain is a good thing in this case it keeps it wrapped together. You noticed he didn't cut into the main crack of the spiral on the left (low side) I would be more worried if it was a straight grain. By leaving that much uncut wood on the high side It probably would have barber chaired straight back. Uprooting it is a big concern by stalling it on the lean forward though. When a tree is leaning like that,
it has compensated and has very strong anchor roots. unless it's a recent lean from root fail or structural defects.
A little undercut is not always a bad thing on those on a down hill fall. The more the base you remove then the tree will 'weigh' forward putting the roots and back of tree under a far greater stress. The down side to it is on hill side falling with bigger trees; whether it be side hill or down hill, it makes for a long reach if you can't go beyond the back of the tree. I don't think I would have cut on the far side first He didn't cut much and he went back there later anyway. Things shift so sometimes you have to go back and revisit a side again . In this case that was the tension side were he cut first. There is no book on this. You are paid well to figure it out. Two escape routes on a danger tree. He didn't mention it but some things are best left unsaid. He was looking at the Hemlock tree pretty hard (The smaller tree that was just on the high side of the cedar snag) Sometimes you clear out your second safety train down the hill and under a log or rock face. It's not a nice thought and Is certainly not taught in the book. What is taught is 2 safety trails on a danger tree and the rest is what you call "over coming a falling difficulty"
If the roots popped and he had no time he could have dove off that high side down.
The Hemlock was a barrier. If the spiral unravelled fast then I would like to have the Hemlock there to better the second option. Doesn't mean it can't end up being a contributing factor to a fatality (May only be 18" dia) I would have done the same.
Some trees make you feel like you want to get sick.
Personally I would have cut more on the high side. I usually do it one handed pivoting off the dogs. You can't feel the pinch as you would with both hands so it's little bites at a time and constantly pivoting in and out.
