Vintage Engine Repairs
- 5:56 PM
- Aug 15, 2019
- australia
It’s discussed on every forum if it’s necessary to tune if you change your mix ratio. Some firmly believe yes - changing mix ratios (50:1 to 40:1 to 32:2 etc) will require a re-tune - more oil = less fuel. They say you can go as far as to seize the engine, others say they just run really poorly if you don’t.
On the other hand, the other group of people don’t think it will make any difference. It’s a change of 1%-2%. It may change the rpm very slightly, but certainly nothing that will cause the average user of OPE anything to worry about.
I decided to test the theory - “do you have to retune an engine, if the only variable is changing the mix ratio”.
