Cerberus
Cerberus the aardvark, not the hell-hound!!
- 2:39 PM
- Jan 20, 2020
- Florida (tampa area)
tl/dr-- Anyone know how to remove this 590's chain-tensioner assembly?
At minimum, the main shaft / long bolt ("Tensioner Bolt") is warped & needs replacement, the actual tensioner-pin itself (the thing that rides back&forth on the Tensioner Bolt) is slightly warped & would be nice but I wouldn't place an order for it alone)
Anyone have 590 service manual for this? Figured I could copy-from my 2511t service-manual, but upon checking it (and it is covered in there), the 2511 "pins" the bevel/worm gearing with that steel plate that rides between the bar & the cover, whereas on the 590 - where the pen is pointed in the picture - there's a "cube" of epoxy-like plastic encasing the bevel/worm gear, I can't just slam it out from the outside of the case (I imagine!) so am a bit uncertain how to proceed, whether the replacement bolt is from Ace or online Echo OEM!
Thanks a ton for how to remove it, a 590/600 guide (I have one but it's hardly 10p long / doesn't address this part), would greatly appreciate it
[[PS-- am guessing there's no way around needing OEM for the other problem, the recoil tensioner-spring is also FUBAR, I was able to jam the plastic starter-spinner-assembly[that the rope winds-around] into the coiled spring and put it back together but it was a fight and the pressure from the spring is awful, so to be clear on that one it's:
- OEM specific only, no 'universals' here I'm gonna scoop at H.Depot, right?
- There's no way around "super careful replacement" IE I have to expose "open spring", being super careful not to launch it, even when dealing w/ a brand new one's proper install, correct? (IF this is a Yes, as I suspect, it makes me at least interested in trying 1 last "bend it back in-place" session, I mean somehow it's all mangled / doesn't mate-up properly but as I recall they're "open coil-springs" on 1 face of that plastic 'casing' they come in, right?)
Thanks again!! Got the 660 stuck in-wood right after dropping a big Oak and had to use the 590 for far more than it's ideal for, or at least at the rate I was being forced/compelled by client to move at, saws took a beating I hate giving-in to that am disappoint
