Roger
Active OPE Member
I have a BR550 that's driving me nuts. The original problem is that it starts immediately after the first or second pull. Runs great for a minute or two, then instantly dies -- like someone pulled the plug wire. Pulling the cord is fruitless (no sign of life) until you wait a 10 minutes or so. Then the process repeats. After pulling the cord about 10 times or more I pulled the plug. It was dry. I squirted some two cycle into the carb throat after removing the baffle. The engine springs to life, runs great and dies.
All this convinced me I had a fuel delivery problem. So, parts cannon time: In separate efforts I replaced all the fuel lines, the primer bulb, fuel filter, rebuilt the carb, and then replaced the carb entirely, and set valve timing. Now the symptoms have changed somewhat. It still starts easily and runs great for a while, then will sometimes sputter and eventually die. Working the throttle as it's in the dying process doesn't help. Eventually it quits. BUT, I can start it again easily until the next event. If it doesn't die outright, it runs great for a time, stutters, and then recovers.
Does ANYONE have an idea about what's going on here? I should add that this blower is 11 years old, is used residentially, and has only about 100-120 hours of accumulated use. I used 89 octane fuel with Stihl 2-cycle oil for about the first half it's years, and then switched to 50:1 pre-mix, alcohol-free in the second half of its life. I treat this thing like my kid. I winterize it properly, and perform all routine maintenance.
Thanks in advance for any insights.
