t4driller
Daddy Day Care
- 6:51 AM
- Feb 23, 2016
- Southwest pa
Put me on the list for a few as well.I'd like one that flows as good as no filter and stops 90% of the dust.
I have one done, just need to cnc them. It uses a k&n with the black filter sock. It's designed for the HD filter housing.
What do You want?
Longer service life, better filtration, or higher airflow?
FFS, just go with a fine white nylon AF and be done with it!
Do You have a CNC program You would share?I have one done, just need to cnc them. It uses a k&n with the black filter sock. It's designed for the HD filter housing.
Chainsaw operators and their kinks!Can't run a velocity stack on any of those filters.
FFS
CAM/CAD or G-code?
I have access to CNC mills, might play with this.
No, I don't have a single HD AF setup for my saws!
I personally will never need one, but thank You and GLWS!Hahahah no. But you can buy one when I make them.
Is that like wearing nylons and high heels when you run a saw?
Speed up airflow to counteract the HD AF inlet elbow restriction?Speeds up airflow
What’s the part number for that K&N filter? I tried using the number B020A4 from the top of it from the pictures but didn’t have any luck.
