Cerberus
Cerberus the aardvark, not the hell-hound!!
- 5:42 AM
- Jan 20, 2020
- Florida (tampa area)
"TL;DR"- album below basically shows where I'm at, got spark, air and fuel as far as the carb, unit has turned-over 1 time out of many scores of attempts, fuel is all new & good and no fuel-filter in place at the moment as that was last thing I tried "crossing off the list", and it did let fuel go all the way up the fuel-line to the carb, but no 2nd turn-over
I took-on this project (an "unknown fault" saw) for a friend and, even though my '77 poulan 25d still sits half-built, I reallllly wanna make this one work and it's on-the-bench now still so hoping for any help!!
I suspect the carb is "crammed up", I did get 1 turnover (literally 1, have probably got 50-->75 pulls on that rope now lol) but cannot get anymore, my routine was:
1- replaced gas, pulling-through all the old gas and even rinsing reservoir (you can look in there and see the fuel filter now, it's not like 10% or even 2% old-fuel kicking around anymore)
2- replaced spark plug, thing was fouled a bit but not terrible, replaced with new gapped & dielectric-greased plug (the tachometer readings from the new plug did seem to be averaging higher than the old plug, but it's guesswork glancing at that while wildly pulling the unit to start it, this has no primer bulb and asks that you start it by full-throttling with right hand and pushing-away while pulling cord with left-hand)
3- After the 1 'burp'/crank of the engine, knowing it 'could' work, I checked fuel-lines more closely and found a slight, tight crack in the line where it enters the carb housing, though it didn't seem to be dripping.....the line in-reservoir looked good so I opened the handle to see entire fuel line and found fuel wasn't making its way to that "tight crack", I ended up removing the fuel-filter and from there the 'tight crack' was now getting some gas dripping out of it, but still no turning-over
4- opened the H&L jets over 1 turn (in 1/4 turn increments) and removed air-filter, figuring "I know I have spark, air and fuel as far as the fuel-line // carb interface", but still no luck....so am presuming this means the crap-catcher in the top of the carb is full/jammed?
Thanks a ton for any insight, would really love to make this thing work again, I know it wants to, compression feels great....while the carb does look clean on the outside, the air-intake (past the filter) had tons of debris, so am guessing carb was hit with a spray-cleaner at some prior point.
Album:
New plug in, tach seemed to read higher #'s but it's very hard to see when doing pulls!
Since it's a no-primer unit, started simply by choking & pulling briskly (with WOT, as per instructions written on unit itself), I've got blisters from "pulling fuel through" the thing, at any rate after removing fuel-filter from the end of hosing, the "tight crack" was now bleeding/weeping some fuel after another attempt at starting-up:
Rest of line looks just fine, only 'problems' I could fathom are poor "Reservoir//fuel line" seal, like the gasket around the fuel-line, maybe vacuum-problem because of that?
So, seeing I had spark, fuel(at least as far as the fuel-line could carry it to the carb), and air (since I removed air-filter on last tests), all I can think is "Is this the type of carb where I can just un-screw that front-plate and scoop the crap from that mesh-screen in there?" but, having never actually opened a carb before, I'm unsure if this is smart to try or if I'll just be opening Pandora's Box & should just tell friend Sorry, can't do it, will need a pro to replace this carb :/
Carb:
Again thanks a ton for any&all insight on this, would really mean a lot to get this thing running
Album:
Carb:
