scooby074
Active OPE Member
- 4:41 AM
- Jul 28, 2016
- nova scotia
Hi guys.
I have a 2011 562xp with mostly original parts and I think I have an air leak (see vid) at the boot to carb joint. Saw has been pressure/vac tested and holds fine after a new base gasket. Carb screws are tight. Boot was checked when the saw was apart, but I didnt see any obvious tears, plus it shouldnt have held vac/press if it was torn??? The fact I can kill it pretty easy with carb clean yet it will hold press/vac is throwing me for a bit of a loop here!
Saw will start and idle fine. Will run WOT ok, but will sometimes instantly stall out off idle.
I noticed there has been several revisions to the intake boot (pipe) and Flange. Ironically my dealer says that the original PNs are still valid parts? I dont have a lot of faith in him TBH. If the intake parts improved sealing it seems like a no-braner for me. Parts are less than $100.
What improvements were made? Do they seal better? What about the "Cold Resistant" part, what improvements were made, Better for a saw that is used mostly fall and spring in Canada?
Husqvarna Flange 505165201 obsolete => Husqvarna 505165202 replacement
Husqvarna INLET PIPE 520291001 obsolete => 583964103 replacement
Husqvarna Inlet Pipe COLD RESISTANT 583964102 Obsolete => 583964104 replacement
