SpaceBus
- 4:18 AM
- Aug 12, 2020
- Downeast Maine
Also, a new plug wire will be here next week, but thank you for the offer.
Indeed, I've been educated and ordering the AM coil was a mistake, but it will at least tell me if the original is still good or not. Didn't have time to work on the saw today. I am able to work six hours a week from home and had to do some time today and then spent the rest of the sunlight milling with the 460. Sharpening the chain helped the little saw compared to the chain out of the box, but it was significantly slower than the 395. I think 10" logs will be the max for the 460. Hopefully tomorrow I'll have some time to trouble shoot the 395 because I was really missing it today.almost all my 395 issues were coil...
im not a big husky guy but almost every response in this thread was made by an experienced user/tech. heck Cus even offered to send you one...on his dime...thats not un common here. id take him up on that before i ever put another AM coil on a saw. (btdt)
also if Shawn Carr says today is monday...its monday.
OEM coil is my bet.
best of luck and keep us posted
That's what I thought when I saw it the other day, but only getting 65 PSI tells me something is up.I don't see scoring. Looks brand new to me.
It does have a schrader valve below the dial, and I did suspect the tester to be not the best, but should still read above 100 PSI. Anything else I can do differently?65 psi is probably from that adapter on your tester. Does it have a valve in the end of it?
Compression gauges are notoriously unreliableThat's what I thought when I saw it the other day, but only getting 65 PSI tells me something is up.
I circled some areas in red that look roughed up, but I agree not enough to cause 65 psi compression
