RIDE-RED 350r
- 2:10 AM
- Feb 8, 2016
- Blossvale NY
101/120/78 I'm pretty sure is where mine is at
That's right around the blow down I'll be looking for. Interesting how high your exhaust is. Thanks for sharing Mike.I like 96 on them. 118-120 and 78 widened.
Yup I've got adjustments to make after learning more too. My XT ended up at 78 with just the BG delete which I think is right near where it should be.Just got my numbers out of my old phone: 100/122/75.
Kinda want to give it a little more intake time after finding that, like around 78-79
I like all the build threads guys, keep them coming, run down and grab that 254 next.lol
It's at 100* and chamfered. Gonna spend more time on the finish once I get the transfers raised and the intake lowered.Nice work, exhaust all done then??
Primary is the one with the big humps..Just timed the new cylinder, came in at 103/127/76 without the base gasket. So as I suspected the timing of the cylinder blew my plan out of the water a little. Since there's no fun in not grinding I'm gonna set the exhaust at 100 and widen it to 70% of bore. I'd like to keep this engine as square as it is now so I'm gonna set the intake at 79* BTDC. Transfers are going to get raised to 123* for 23* of blow down and shaped more to aim them toward the intake. I'm gonna leave the lowers alone, Joe took the big humps out of his and I'm curious to see if this saw will run just as good with them in there. I think the new charge will favor the primary transfer more if I leave them there. Be back in a few hours, I got some grinding to do.
Thanks Mike, I always manage to confuse the nomenclature. Makes me second guess leaving them there.Primary is the one with the big humps..
Yep, 35.98mmWidened to 70%?? If I recall that is just about 36mm on the nose.
