Might also make a good stroker with a 385/390 crank and a xpw or 52mm am top end if the 385/390 top is to far off to work.
Steven
and what do you know about saws? well?I know of a guy with a 372 that has 38mm stroke. The crankshaft fits in an un-modified case.
Only what i've read on the interwebsand what do you know about saws? well?
Did you bore the 372 crank to accept a 395 rod?I know of a guy with a 372 that has 38mm stroke. The crankshaft fits in an un-modified case.
The 6003 bearing sure opens some possibilities. It's actually thinner than 6202s...so it'll fit more than flush in the pocket. And yes...much easier to machine the seal pocket appropriately.
Snap ring is an interesting idea as the clutch on a 372 tightens against the bushing... so...get it to tight to the snap ring .... hmm.
Lots to think of on the bottom end.
Thanks @jacob j.
I was thinking more along the lines of using the 372 crank. But is the juice worth the squeeze is the question.my concern is more of how to do the crank seals, especially PTO side, assuming the larger crank is used, then the pto bushing won't work. to me this seems like the larger challenge.... beyond fitting a different top end.
I'm still trying to wrap my head around how to wallow out the bearing pockets. if I could accurately machine it, then you could use 390xp pto proprietary bearings on both sides ....
Maybe port a 390xp and slap a 372xp sticker on it? Would have to look closely to tell the difference at a gtg. Most average suckers (stihl guys) wouldn’t know the difference. Work smarter not harder. LolThe 390 piston uses a 13mm pin. 372 12mm I think. Aside from the stroke issue... there are other issues
There's a lot to work out for sure. Would probably make most sense to use the 390 crank too but it's a pile of work I think. Lots of different little things to consider.
If i end up with some lathe time I'll see what I can come up with.
