stumpyfine
- 12:39 AM
- Feb 13, 2017
- Cambridge New Zealand
Hello all im Phil from New Zealand, this is my first post, I have a MS361 with 440 crank and 460 cylinder. Used a 440 carb,272 piston ,ms360 flywheel and modded 361 muffler ,all running good with original covers. Cylinder holes required a lot of slotting to fit the different bolt pattern and cases needed machining for crank clearance.
