Lectro88
Active OPE Member
- 4:05 PM
- Feb 19, 2018
- North Carolina
Hello All.
Today I did some preventive wrenching on my New 3120. Less than a hour run time on it.
First for those that don't know me.
I'm Ole Skool.
I run 32:1 And good oil at that with NonEth. Fuel.
Knowing this giant was factory dialed 50:1 and my stubbornness would be effectively running lean with 32:1.
So I found the main jet at 1.1 mm as known by many and addressed and corrected that problem.
Also in the 1/2 dozen cuts I made with it.
I noticed excessive exhaust oil on cylinder fins crawling and making a mess.
Oh No No No. ! Homer don't play that either.
I removed the muffler and found the surface not true and hand filed it true.
Also pleased to find a much thicker meaty entry surface than expected. Well over 0.125" thick. I have found sheet metal on many others in years past.
And didn't like the muffler bolts recessed and right against shroud.
I can see the bolts rusting, eroding or pitted and socket not able to really get in there to remove especially with most sockets chamfered so there's you a 2 for 1 problem out of the gate let alone how we know muffler bolts get stubborn.
So I added Stainless flat washers and lock washers.
Really happy with how everything turned out.
Can hear the richer blah at high rev. Not coil cut out lean over rev as before.
And I was able to see a little blue mosquito repellent clouding the area as expected.
I will try to load pics.
May take a few attempts.
It's giving me problems uploading already.
I'm Ole Skool.
