Junk Meister
- 3:29 PM
- Aug 10, 2016
- Nebraska
You would be a CRUEL dentistIt will be
Try it out on some walnut....
This might help on the mill if it don't overheat the cutter.watched a video with old man walker from walkers saw shop He said leaving the gullet helps clear the chip out the back of the tooth. He didn’t say it was faster. He said the chain would cut straighter in longer cuts. Voodoo
Found some. Not sure if it is "old" enough. Says A1 on the driver. Any good?If I could find some I'd buy it again. Seems the old Carlton stuff has dried up
Test ran it stock. Hit a nail. Filed on it a bit. Ate that Cross file right down. Have pic in my cell phone.That might be old enough to not be Oregon made
A1 is .050, A2 is .058 and A3 is .063.This might help on the mill if it don't overheat the cutter.
