25.4x200mm brushcutter blade?
Patric Mudge
6:30 AM
UK
Hi Everyone,
Need some advice for a brushcutter blade. I have a Honda UMK435 brushcutter that I bought earlier this year and absolutely love. Was unsure about 4 stroke but I couldn't have been more wrong and puts my older 2 strokes to shame! The problem is getting decent blades. The only blades I seem to be able to find are the pressed steel ones which are okay for light brush but when you have 1"-2" trees in between the teeth just aren't man enough for the job. Does anyone know of some carbide tooth (circular saw) blades that are 25.4x200? All the ones I can find are 210mm which would require modifying the guard.
Thanks!
mgr1
7:30 AM
Belgium
You can buy them from Dewalt. Over here there are conversion rings for axle diameter included with the blades.
Car wash guy
1:30 AM
Bristol va
Been punching out skill saw blades with a slug buster fits right on.Been sawing 3 inch saplings with it the last couple days I'm impressed
Sent from my Lenovo TB-X103F using Tapatalk
Patric Mudge
6:30 AM
UK
Ah I never thought about just buying a 30mm to 25.4mm adapter (Doh!) I am tempted to try one of the stihl chisel tooth blades and seeing what they are like as you can sharpen them with a chainsaw file.
Trouble is there's usually hidden stones in with the brush or little bits of metal and I have had a carbide tooth come off a circular saw before and hit me like a .22 air rifle. I've also noticed that brushcutter blades are 10,000rpm and most saw blades are 6,300. The specs on the Honda say that the RPM with a blade on max out at 9,300 so it's a little risky, don't fancy clipping a rock and having a blade shatter into my shin. Then again if you guys are running them without issue then they can't be that bad.
I just looked at slug busters! They are pricey in the UK! £54 ($75) after VAT!!
Had a little fun with the brushcutter blade on its last legs today. It doesn't do too bad even though it burns through trees instead of cutting them! DSC_0027.JPG
mgr1
7:30 AM
Belgium
In the Oregon catalog you can find special blades for brushcutters. Not cheap...
Patric Mudge
6:30 AM
UK
Maybe I will try a chisel tooth blade and then give a circular saw blade a go if the chisel blade can't handle it. I'll have to shop about and find a circular saw blade with the correct RPM rating. Seems like the larger the blade gets the lower RPM rating it has.
Car wash guy
1:30 AM
Bristol va
Go with a smaller blade.You are gonna bend anything you put on it.If you bend a smaller blade it's no where near as noticable.I like the finer tooth blades like a ripping blade.They don't bite as hard or jerk you around.Just my 2 cents
Patric Mudge
6:30 AM
UK
I would struggle with anything smaller than a 200mm I think. I already get annoyed when the head gets stopped by bits of brush and I can't get underneath to get to the main stalk to cut it down. I will give the chisel tooth one a go and then see what it's like from there. When that goes wrong I will look at getting a blade and just use a spacer if necessary
Car wash guy
1:30 AM
Bristol va
I hear you man.I have been swinging mine for the last 3 days on and off.Im way behind on the brush growing around my house.Been on the road for 5 years.Got a little time at home now and I'm trying to get caught back up.I bought this blue max off of Amazon 2 years ago.Im usually a couple seasons and buy another brush cutter kind of feller.Im super impressed with it.It was under 100 dollars.
Patric Mudge
6:30 AM
UK
Yea it's crazy how fast things grow when your back is turned. I've been using mine to cut a hedge down that had grown to be 13 feet deep! I don't blame you for buying a new one every few years! They usually get temperamental after a year or two which is why I've changed to 4 stroke. The engine is crazy smooth and much more torque! Plus when I have a heavy blade on it pops a little on overrun when you come off throttle and that puts a smile on my face!
