- 6:05 PM
- Jan 24, 2018
- Extreme Southeast CA
Got this 2139 used recently from a guy on one the saw groups on fb. Think it’s an ‘08, used by a tree co. Checked it out when I got it, pulled muffler, 150psi compression. I like it, but apparently it’s like all my other saws and is mad at me at the moment. Running wonky when tilted, so vac/pressure test, crank seals leak. More vacuum leaks than pressure. Boot seems to be a problem area, was hoping that was all it was, but it only almost had a hole. So, pulled the case apart and had to take piston off to get sheet metal bearing holder gasket thingy off. Discovered the rod has been rubbing one side of the piston. Inside of rod and bearing shows a little heat signature on that side. What do y’all think? Something crooked/misaligned it would seem to me.
