- 2:17 PM
- Dec 3, 2015
- Banner Springs Tennessee
Here it is gents. Lots of guys want to get in on this just for the fun of it. Those guys are turned off when some of us that have built a lot of saw start talking about two piece heads and boost ports.......installing non-standard cylinders, etc.
On the other hand.....those of us that have built lots of saws are bored with just widening the ports a little and calling it done.
Now, looking at the poll I cast yesterday tells me that more people are interested in just sticking with the "what's in the box" approach.
This brings us to a "what the hell should we do?" point. lol
I was texting with my friend Mike Lee @mdavlee last night and we think we might have a solution that will be good for us all.
Class 1
This class is for guys that don't want to do any machine work. Three cylinder options are available for this class. You can use either the FarmerTec , the Hyway, or the Cross top end. You are allowed to use any aftermarket rings......OEM rings are not allowed. You can use any circlips, or wrist pin bearings you deem necessary.....AM or OEM. You must use the piston, and the wrist pin that matches the cylinder that you choose. If you use a FarmerTec jug......then you have to use the FarmerTec piston as well. You can use any gaskets or seals that you choose......AM or OEM. OEM fuel lines and filters are legal. All other rubber bits (intake, impulse, etc) must be AM. You must use the AM carb that comes with the kit. The carb must be the one that came with the kit (we might make an allowance here if your carb is complete crap. If that is the case, you must make note of that in your build thread, and then only another AM carb that is a replacement 1122 series carb can be used). The kit muffler and cover must be used. You can mod the muffler any way you see fit, except to create a tuned expansion chamber type of unit. The bearing and crank that come with the kit must be used. The oil pump can be modified to increase flow, and the worm gear can be AM or OEM. The coil and flywheel must be AM. Recoil parts can be changed to OEM with the exception of the cover. Starter rope, and handle can be OEM or AM. No machine work of any kind is legal in this class. No sanding, milling, filing, lathe work, non, nada. Base gaskets can be AM or OEM or homemade or non-existent. No external transfer ports can be used. No finger ports or bridge porting allowed. Working choke is required. Airfilter must be from the kit, or the white AM HD2 style replacement. No MaxFlow setups allowed. Air filter cover must be installed. No modifications can be made to the covers. Chain and fuel will be supplied at the event. I reserve the right to add to these rules if I forgot something, but the meat and potatoes will not change.
Edit: Carb mods in Class 1 will be limited to spring and jet changes. Jet meaning if you gotta drill a welch plug or whatever to get it working good then that's ok. Just no boring the carb throat or venturi.
Edit: Just to clarify. Port work is allowed in this class. No finger or bridge ports. No external transfers.
Machine work to increase compression is not allowed in any form.
No BB kits.
Class 2 :
Same rules as Class 1 with these exceptions.
Machine work is allowed to the squish band, cylinder base, and piston.
Finger ports, and/or bridge ports are allowed.
No two piece heads.
OEM carbs are allowed as long as they are intended for the 1122 series. Carbs can be modded for flow, but a working choke is still required.
OEM intakes and impulse lines are allowed....but must be intended for the 1122 series. No intake blocks. No 084 intakes, etc.
Fuel filters can be gutted for more flow.
MaxFlow, or OEM air filters can be used, and covers are optional.
OEM coils and flywheels can be used.
Edit: Just to clarify. No BB kits in this class.
Class 3
Same rules as the first two classes with these exceptions.
You can use any aftermarket top end. Period. Fit one from a 090 if you can.
Two piece heads are legal.
External transfer ports are legal.
Use any carb you like. WB....HL.....whatever.
Use any coil/flywheel combination you like.
Methanol, Nitro, Oxidized fuels are legal.
Make your own chain.
Tuned pipes are legal
Air filters are optional.
Fuel filters are optional.
In other words....in this class anything goes as long as you use the kit parts for the bottom end, and an aftermarket top end of some kind.
EDIT TO ADD CLARITY: Any aftermarket pistons and jugs are legal. The piston does NOT have to match the jug.
Now........we went from a simple event to one with a chit ton of rules. lol
Dave @Definitive Dave offered up 250.00 is prize money for this event. We will find another 50 bucks to throw in.
That will be divided this way.....
Class 1 $100.00 to winner.
Class 2 $100.00 to winner.
Class 3 $100.00 to winner.
Any of the saws from the first class can run in the second or third class.......and any saw from the second class can run in the third class. This way if one of the first or second class saws is a real bad ass, it's possible to make a clean sweep and win every class. The winning saw from each class will be torn down and inspected. If anyone is caught cheating they might be subject to a Tennessee ass kicking. Remember......this is supposed to be a fun event.......not a World Championship.
Now.......what did I forget?
Class 1
No BB kits.
Class 2 :
No two piece heads.
Class 3
