- 9:50 PM
- Dec 6, 2016
- Dryden, ON, Canada
You will have to gently work it off prying one side at a time. Those washers are a very tight fit on the shaft.
This pump had two threaded push bolt holes. Screwed the lower handle screws in and used an 8mm socket. Popped right off.You will have to gently work it off prying one side at a time. Those washers are a very tight fit on the shaft.
What a good idea on the puller!This pump had two threaded push bolt holes. Screwed the lower handle screws in and used an 8mm socket. Popped right off.
Then I made a puller out of a 3/4 x 1/2" pipe reducer, 3/4 coupling, and pipe plug drilled and tapped to 3/8"-16.
Screwed a bolt in that and pulled the pump gear.View attachment 308607 View attachment 308608
Kudos to you sir on the puller idea.What a good idea on the puller!
Do they make them in a Meteor?The 630 Super 2 windowed piston is what you want.
Thanks David@Huskygasaxe has some stuff for this chassis for sale
https://opeforum.com/threads/various-parts-husky.25117/
I like parts tanks ill check it out@Huskygasaxe has some stuff for this chassis for sale
Meteor makes both styles, the super 2 piston is full window.Do they make them in a Meteor?
Or OEM ONLY?
Is that a full circle piston like mine or full window?
If you have an extra set of case bolts laying around use those to pull everything off the oil pump. That's what I do.Quick question.
This thread is a little more active, so I'm asking here.
Got a 262XP I'm taking apart to put crank seals(probably bearings too) in.
How does the oiler pump drive come off?View attachment 308228
If you’re on social media by chance? Get ahold of Corey Corp. He’s in Oklahoma as well. He might have one. Tell him Howard sent ya.Anyone have a 266SE top cover they want to part with?
