- 2:31 AM
- Jun 5, 2016
- Northwoods of Wisconsin
For starters, 272xp cylinders are not scarce as hens teethe. You can order new ones all day long from any Husqvarna dealer. So I fail to see the "MacGyver/Mad Max" type of necessity here.
Ever notice that there's not a big bore kit available for a 272xp? That's because it's already a factory big bore on a 60cc frame. At some point you just start running out of huff and puff.
@Spike60 Popping bases is a real thing, base strength is always a fairly high thing on the list of consideration when modding. Plus what happened to the cylinder extension, that's part of the strength. What piston was used will have some bearing on the overall height. I don't know what it could be with the differences in bore diameter and pin diameter.
There's no explanation and I can't see the pictures good and there's no vidja of it running to say much about it, who knows, might be the next great hybrid build out there? After all someone has to be the first to try such things out, so at the very least he gets an E for effort.
