JT78
- 6:26 AM
- Aug 29, 2016
- Burlington, nc
Ok so the 066 I am rebuilding had swallowed something at some point and the exhaust port and piston were damaged. I had planned to port this saw as well but had to raise the roof a bit more than I had wanted to. So the final numbers I ended up with are intake,transfers,exhaust 82/118/94
So is this thing gonna run decent?
I did a lot of research looking for port timing numbers and it seems a little high on the exhaust and long on blowdown but everything else should be in check.
Also I am running a Dukes pop up piston so I think compression should be good still ?
Pic is from before I pulled it all apart.
