WYL Carburetor Adjustments
lindylex
Active OPE Member
7:56 PM
Earth
I have the following carburetor WYL. It is from a Troy-Bilt backpack blower. I can not find where the carburetor adjustments are for high and low. It seems the closes is the adjuster screw for idle. I rebuilt the carb and it idles but when I press the gas it cuts off. I need to adjust the carb to get it to not fall on its a$$.
Thanks
Wonkydonkey
Plastic member
12:56 AM
Sussex, UK.
Keep us posted if it works or not the same carb etc...
I was only going off what you said the carb was (Wyl) and I saw the walbro
backhoelover
I like tools
7:56 PM
lincolnton nc
its 100% fixed jet carb for the high and for the low if there a adjustment it will be in the center of the rotor. will either take a micro d carb tool or you will need a 2.5 mm flat head screwdriver and a 2.5. bolt to pull the limiter carb
Wonkydonkey
Plastic member
12:56 AM
Sussex, UK.
I’m, unsure how one would fit the throttle cable, as it seems like the attachment point has been broken, well that’s according to the manual it has.
And yes I read through the manual and came to the same conclusion that it was a fixed high. And probably only been adjusted with the throttle stop.
backhoelover
I like tools
7:56 PM
lincolnton nc
Thanks
Can u get straight pic of metal ring on pic 2. Need to see inside the brass section
lindylex
Active OPE Member
7:56 PM
Earth
lindylex
Active OPE Member
7:56 PM
Earth
After speaking to a Walboro rep they gave me the following model number for the carburetor "Walbro WYL-247A".
backhoelover
I like tools
7:56 PM
lincolnton nc
echo dealer is the cheapest see what your local dealer will do. some will sell them some will not
backhoelover
I like tools
7:56 PM
lincolnton nc
you can also make them out of the 2 piece briggs carbs that has the long brass emulsion tube behind high adjustment
backhoelover
I like tools
7:56 PM
lincolnton nc
dont think about things broken. pretty sure the throttle has lead z casting that is longer on the end to keep it from slipping out
Wonkydonkey
Plastic member
12:56 AM
Sussex, UK.
AVB
6:56 PM
Pluto
Just hope they are better made than the ones I got off Amazon. The 4 mm hex is loose fitting and the large Pac Man was too loose but I already had that one.
lindylex
Active OPE Member
7:56 PM
Earth
I just realized that I have the Micro D adjustment tool. I will give it a try and report back.
