Would you run it?
Fruecrue
certified hand catcher
12:52 AM
Alden NY
Cross piston for the 066 build-off.
Fruecrue
12:52 AM
Alden NY
The way I see it, the piston takes the most stress between the pressure applied to the crown and the bosses that apply that force to the wrist pin.
The flaw is on an arm supporting the piston skirt to reduce flex and rocking.
Am I wrong?
smokey7
12:52 AM
Detroit
How deep is the pores? If its shallow i may run it. But if you can get another i would. Especially if that top end will stay on that saw.
12:52 AM
that spot looks to me like the metal was too hot and started to melt
bikemike
11:52 PM
Cottage grove mn
Intake or exhaust side. If it's the cool side I'd run it. Exhaust side I'd sent it back
fearofpavement
12:52 AM
Georgia
Those types of "voids" are common in many types of metal castings. A lot of times they're only visible when the part has failed. I don't think this one is significant enough to make a failure likely. I would prefer a piston not have this but wouldn't worry about it if I put it in a saw.
