Windsor 50 a
jakethesnake
I Am The Snake
9:15 PM
Here & Now
Couple guys asked if I’d give a half assed review on this stuff. Old stock from eBay. 46D26489-0639-4D47-B269-78A7DA968ED6.jpeg
jakethesnake
I Am The Snake
9:15 PM
Here & Now
12A36294-1C01-42BF-8E09-9EED4B8626E8.jpeg 31824900-BA5B-487B-9A8A-344903C08712.jpeg Test subject live oak. Likely willow oak. Not 100 percent on that
jakethesnake
I Am The Snake
9:15 PM
Here & Now
34B6ECB9-A78E-4575-BE1A-070D4241DDEE.jpeg Stump is little jacked up but things went well enough tree went where I wanted it. Bar was too short. I’m not an expert so I’m good with this one.
jakethesnake
I Am The Snake
9:15 PM
Here & Now
F97B67AC-ACF3-482D-90C9-05E0FA883BAE.jpeg AA6B0FA3-DBE5-477B-95F2-C8EF19BA7641.png After one tank. No need to file at all. Stretch was very similar to Oregon. Had to stop once to tighten it. Chain itself did get pinched a couple times cutting off some heavily loaded limbs Bar was completely buried for most of the tank.
jakethesnake
I Am The Snake
9:15 PM
Here & Now
Chain self feeds well. Did notice some chatter. The bar tip was vibrating quite a bit when I cut some limbs in the 12 ish inch range.
jakethesnake
I Am The Snake
9:15 PM
Here & Now
Chips were quite thick so rakers /drags are low on this stuff. I noticed it stopped the saw a couple times. That’s not something that really happens with that setup. I couldn’t feel the vibes through the saw even with worn out av rubbers I’m thinking this stuff is semi chisel instead of chipper. Whatever it is cuts well
jakethesnake
I Am The Snake
9:15 PM
Here & Now
I did get a tank through a 346 with some Oregon stuff on it. To be fair the Oregon was .325 vs the Windsor 3/8 The Oregon was also chisel. The Oregon needs a nice little touch up / sharpening. This stuff seems the very same as when I started with it. Never hit any dirt today with either This stuff also cut the shaggy stuff /thicker bark. All in I’m liking this stuff very well. I’ll get some dead trees somewhere to continue this
Wagnerwerks
9:15 PM
Pa
In that third pic I had a you tube video flashback and thought you were going to drop it right in the truck bed. ;)
