Will It Cut..??
Brush Ape
Direct Connection
9:53 PM
Metropolis, Il
But you know the saying.. beauty is in the eye of the beholder. :rota2:
There’s a difference between saying and doing. Really beauty is in a roostertail comin’ out the ass end of your clutch cover. It’s in results. As time wears on you begin to realize it is in the endgame.
BCE30C34-0B22-4BCD-93B7-765F5DE808D3.jpeg 42CBD7EC-AB5C-4B3E-86CE-7B1F79F31CE7.jpeg ADB02CF8-F8F6-4E58-99A7-D4FE1F00B43B.jpeg D2AEC787-66AE-47E2-9E2B-AEB4C3D2819F.jpeg FC3B9645-3CB3-4789-B8C8-53B7EAA59B42.jpeg
Deets066
AKA Deetsey
10:53 PM
Brush Ape
Direct Connection
9:53 PM
Metropolis, Il
I’d think that chain lube might hurt more than help. Leaves film that bar lube may not be able to get through.
:nusenuse:
If there’s a film of teflon on all my rivets, drivers, bar rails and sprocket where would the bar lube go?
He's probably cleaning it off as we speak.
I was turning down my oiler.
P.M.P.
Stiff Member
10:53 PM
Michigan
4:53 AM
Somebody send me some of this square filed for me to try out and learn to file from...
Have You found someone to send You some square ground/filed chain?
davidwyby
Rural desert logging
7:53 PM
Extreme Southeast CA
Not yet. Hadn’t really pursued it that hard.
I’m sharpening on the half tank over here with all the dry dirty stuff I cut so it might be a waste. :-/
