why does H&L supply say 372 Hyway bb kit wont work on xtorque ?
Willoughby
6:02 AM
NW MT
why does H&L supply say 372 Hyway bb kit wont work on xtorque model ?
I wanted to order a bb pop up kit for my 372 x torque but it says it wont work , does any one know why ?
I was expecting to replace carb, intake, air horn, and top plastic to make it work but is there something im missing here ? thanks in advance for any replies
Disciple of Monkey's
7:02 AM
I dont see why it wouldn't work.
Cant believe @Stump Shot hasn't jumped in here yet.
Waiting for you to ask first. :p
They say that as it's not a direct replacement, as you already know, an adaption needs took place to make it work. :)
beaglebriar
The Peanut Gallery
8:02 AM
Warren Center, PA
All you need is a 385/390 intake boot. Use the XT carb and elbow.
I'll take the XT parts off your hands if you decide to part with them.
7:02 AM
... and, if you go this route, leave the divider in the carbeltater. Elbow is okay too.
qurotro
Cookie Cutter
7:02 AM
Ar
The XT engine shroud is taller than OE too if you dont mind that.
7:02 AM
Also has the decomp hole that is no longer needed. I usually fill it with epoxy to keep the air flow going past the cylinder. It's probably just me worrying too much, but it certainly can't hurt anything.
Willoughby
6:02 AM
NW MT
one more question I bought caber 52 mm rings for my Hyway kit and the rings are to thick for any piton I have -had to use the kit rings ?
Willoughby
6:02 AM
NW MT
Measure the thickness of the rings supplied and see if those are available in the Cabers.
I didn't know you could get different thickness rings - haven't seen that listed just size in mm 50 52 ect ?
Willoughby
6:02 AM
NW MT
why would you want to delete de comp valve ?
