Which 63?
Farmchuck
2:13 PM
Nepa
Hello fellas I have a Stihl ms200t & I would like to get a few loops of chain for my 12” bar. I’ve heard you guys speak of a 63 Stihl chain but I think I’ve read they’re are different 63s? Looking for recommendations of which ones work best for you guys & where I might source some. My local Stihl dealer is pretty much a green Stihl only chain seller.
Thanks Chuck.:)
full chizel
¯\_(ツ)_/¯
2:13 PM
USofA
The green version is PS3 and cuts just as fast. The bumpers don’t even effect anything in the cut. Some prefer the green version on a climb saw because it is a little safer.
Farmchuck
2:13 PM
Nepa
The bar on my saw says:
12”
44dl
.043
P.M.P.
Stiff Member
2:13 PM
Michigan
Just don't want to go bore cutting with the green but it's just as fast from what I understand.
PA Dan
2:13 PM
White Oak PA
I go for the PS yellow for a couple reasons. First is I fell it cuts faster and if I have to bore cut I have no worries. The second is I can square grind it on the first sharpening and then it surely is faster.
Johnmn
1:13 PM
Minnesota
You should grind some for me! :D
Also I have some 350 parts here for you if you still need them let me know.
PA Dan
2:13 PM
White Oak PA
Want to send them or have me get them from my dealer? Let me know.
Since @Wolverine grabbed me a minty 346 from CL out his way I have decided to not mess with the 350 and gave it to a buddy.
Farmchuck
2:13 PM
Nepa
My bar says 12” 44dl .043
Farmchuck
2:13 PM
Nepa
Is there a chain similar in this type chain, gauge?
Johnmn
1:13 PM
Minnesota
I'm building a 2150 (red 350), I'm leaving the original 44mm p&c on it. I was thinking of setting it up with 3/8 lp. I have 2 red NE 346's and one more to build thats gonna get a oe 346 top end.
Farmchuck
2:13 PM
Nepa
I'd swap to the 3/8" Picco .050 bar and get the PS chains for it. In the .043 guage I believe your limited to the green chain.
Thank you. I may do that!
