firefighterwolf
- 8:57 AM
- May 27, 2016
- Southern Oregon
Yep. I just went looking, and it appears to be an 045. Based off of the recoil side.It's an 045/056. the 031/032 choke lever is on the air filter cover.
if you are planning to buy it measure the cylinder, the larger 056 Mag2 cylinder is the most desirable and might be worth more than the rest of that saw
Dave
Not really unless you consider removing the top cover and muffler to get an open view into the exhaust to drop a tape in it.Is there a way to easily measure it?
I agree with Jim looks like mine but I need a muffler for mine.It's an 045/056. the 031/032 choke lever is on the air filter cover.
View attachment 41434 View attachment 41435
Here is a saw that I just came accross that may help you determine if this is close to what you are looking at. Craigslist ad so the listing may disappear.
Stihl 045AV Super
https://nh.craigslist.org/tls/5844760554.html
Stihl 041
https://nh.craigslist.org/grd/5823739625.html
Remove the muffler and use a Popsicle stick. Run the piston up to crimp it a bit. Measure with your dial calipers. Accurate to plus/minus 1/64".
