What model do you think this is
Motorhead
Cantre Member
1:55 AM
Tampa Fla.
All of the above will interchange,also 141 142 137 etc Husqvarna,clutches sprockets,oil pumps.with a little tweaking the husky motors inter change.Poulan 2900 4620 2500 295 and a few more.These are the ones I own.Fogot to mention the sprockets come in 3/8 lo pro or .325 the poulan you Have if it hasn’t been changed came from the factory with .325 sprocket
Lone Wolf
1:55 AM
Nj
OK thanks I got to look at the sprocket.
Lone Wolf
1:55 AM
Nj
So it turns out he had a reg 3/8 bar and chain on it and it ate the teeth off! Can it be setup for standard 3/8 or what now that he bought a new bar and chain? will a Husky bar from my 254 in 325 size fit this saw?
Motorhead
Cantre Member
1:55 AM
Tampa Fla.
The husky .325 bar will fit.
Lightning Performance
1:55 AM
East of Philly
I spoke to Wolf on the horn today. Did some searching at hls reveals many setups fit. Should he run 3/8 on it?
I say sure with a muff mod. I I did find a 3/8 lp set up on a Poulan 2.1 wood boss ooooo.
Should I order him a 3/8 set up or just send up this used 3/8 lp setup?
I run lp on everything small. This might be easier to get parts for local. The 3/8 spur is not common to these saw but they do sell them for older models.
I'm no Husy guy but do know what is in these tiny screamer Poulans. Sent one 141 out for a parts carcass last month. I have one runner out of five burnt up saws like this. It has the lp stuff on it. I have no other drum or spurs for them.
Chime in soon. The saw needs get back with it's owner to cut wood.
1:55 AM
East of Philly
Ok lp it is. Someone send him another spur. This one is worn some. It will work for now.
Me too GFY Clause @your service. Um fiddy dollas please...
Am I an eggspurt now? :rolleyes:
Lone Wolf
1:55 AM
Nj
So what did you dig out clutch any bar for that LP?
