What are the chances
mirage
11:55 AM
idaho
I got a stuck piston on a Titan saw. Lets say I got it to move. What are the chances of it ever working. If I get it to move I will take it apart and clean. Anyone ever have any luck doing this. I know there are a lot of variables. Rust broken rings . Should I just take a BFH to it and free it up then take it apart and go from there. Going to start with the Kroil. Thanks
bagpipingtrucker
1:55 PM
US
Everyone talks about ATF to free a stuck piston. At least try to lube it before you start whacking on it.
Homelite collector in training [emoji879]
bagpipingtrucker
1:55 PM
US
sawfun
10:55 AM
Portland Oregon
I had two stuck pistons on my Titan RE. I kept trying PB blaster for better than two weeks daily to no avail. I tried the 50% mix of acetone/ATF and within 24 hours it came free safely.
mirage
11:55 AM
idaho
I will mix sum up. Did you still have to take it apart and install rings or piston or just fire it up.
Derf
1:55 PM
Long Island NY
ATF have very short chain lipids for lubricant, and acetone as a petroleum distillate breaks down lots of corrosion. It works well. A commercial product that is head and shoulders above PB Blaster, WD40, and other household products is “Kroil”. But in a pinch ATF and Acetone is the next best thing.
ucm931
1:55 PM
Michigan
For the ATF/acetone mix, try to use a non-synthetic tranny fluid like a Dex3/Mercon. In my experience, the synthetic stuff has a tendency to separate from the acetone pretty quick....not the greatest thing when ur doin a soak.
sawfun
10:55 AM
Portland Oregon
Being from 1947, yea, it had to come apart. It will get a new top ring on each piston, deal's and a complete fuel system clean and rebuild.
mirage
11:55 AM
idaho
where can you find piston rings for a Titan 60
sawfun
10:55 AM
Portland Oregon
I dunno, I got lucky and was given the two I got. The Titan twins have 3 rings, two on the top and one on the bottom of the piston. The top ring was frozen and I was stupid and tried to remove it carefully but should have tried a sonic bath first. Maybe it still would still have been stuck, I'll never know.
mirage
11:55 AM
idaho
I just got into Titan saws. I like the looks of them . I do not know what a Titan twin is . I will google it but if you got a picture of it can you post it?
mirage
11:55 AM
idaho
Man that is WAY cool. Found it on google. If you come across another one please let me know. I think I need one. But don't tell the wife.
sawfun
10:55 AM
Portland Oregon
I've come across two of those in this life. The other was a Bluestreak that I sold before I was into the really old saws. Most that have them know what they are a d won't part with them. I have an 11 foot bar for mine.
mirage
11:55 AM
idaho
