WANTED Wanted complete MS660 tank
MR_T
10:23 PM
Wisconsin
I have a new OEM tank, but of course it doesn't come with the parts (Switch shaft, Contact spring, Axle, Throttle trigger, Trigger interlock and so on). So I'm looking for a junk tank that has what I'm in need of. Not sure what my chances are, but I'll give it a try before I order all new parts.
Thank you.
singinwoodwackr
9:23 PM
moon
Thank you.
I have all the parts for 066s and a few 660 housings (they are wider). If the trigger parts are all the same I have everything. Try listing the exact pt#s you need and I can see what all I have.
jacktheripper
Papa Squat
9:23 PM
Wyoming
I was just going to say talk to Chris! Haha. Also, Randy had some about a year ago or so.
MR_T
10:23 PM
Wisconsin
I think this is it. Thank you
1.) 1122 182 0902 - Stihl Switch shaft
2.) 1130 442 1602 - Stihl Contact spring
3.) 1122 442 2500 - Stihl Axle
4.) 1122 182 2100 - Stihl Support
5.) 1122 180 1500 - Stihl Throttle trigger
6.) 9371 470 2600 - Stihl Cylindrical pin (DIN7) - 5m6x16
7.) 1122 182 1502 - Stihl Throttle rod
8.) 1117 182 4500 - Stihl Hook on spring
9.) 1117 182 0805 - Stihl Lever
10.) 1122 791 0600 - Stihl Handle moulding
18.) 1127 141 8600 - Stihl Impulse hose
19.) 0000 989 0812 - Stihl Grommet
20.) 1122 182 0700 - Stihl Grommet
21.) 1122 123 7504 -Stihl Grommet
22.) 1122 123 7503 - Stihl Grommet
jacob j.
Only the weird
8:23 PM
Coastal Oregon
I think the switch shaft is the only part from the control group that's different between 660 and 066. The tank vents can be different as well depending on the age of the machine.
singinwoodwackr
9:23 PM
moon
Yours doesn't have the axle, #3?
I should have all that except maybe #4
singinwoodwackr
9:23 PM
moon
Post a Pic of your tank
singinwoodwackr
9:23 PM
moon
I'm not by it at the moment, but here is the image from the ebay listing.
Man, that is weird it has no pressed in axle. I don’t think I even bothered removing those from the junk tanks I had.
What is the pt# on the orange top? Will see if it matches mine.
At least they included a vent 🙄
MR_T
10:23 PM
Wisconsin
I'll have a # when I get home in 3 or 4 hours. I can't make it out in the picture I have from eBay.
singinwoodwackr
9:23 PM
moon
So, have most of this. But, found a bunch of different throttle rods, hmm.
Top group is like what I used on my early 066 FT. Bottom may be for early 064s.
And, another bag with 3 more designs...
singinwoodwackr
9:23 PM
moon
So, @jacob j. ...any ideas on all the different throttle rods? I know the early 064s with Bing 49s used a different rod than the later 066s but that's about all I know on that.
MR_T
10:23 PM
Wisconsin
This is all new.. I'm trying to build a new 660 from the ground up with nos parts.
singinwoodwackr
9:23 PM
moon
Oh, well I don’t have new parts. If you need those I would just have a local dealer order them for you.
jacob j.
Only the weird
8:23 PM
Coastal Oregon
I've circled the later style throttle rods in your picture that would be compatible with 660.... the throttle rods not circled are the older style that came on the 064s with the non-clear tanks.
