RIDE-RED 350r
- 6:14 AM
- Feb 8, 2016
- Blossvale NY
Ok guys, I bought a new 395 clutch cover for my 394. It didn't take me long to realize that there is a subtle difference, the chainbrake mainspring for the 394 cover is longer, and the corresponding spring cover is shaped differently as well. No problem, I'll just get a brake spring and cover for a 395 and all will be squared away, right? WRONG!
The spring is in fact shorter and seems to fit my 395 cover, but the 395 brake spring cover I ordered is shaped just like that of the 394 and does not fit the 395 cover, at least not without modification. The spring cover I got was backordered, so my dealer pulled one from a brand new 395 to square me away. (Kudos to GKS for that)
I have checked Partstree and the part number checks out, the picture of the part shown on the exploded diagram looks like the correct part... But here I sit with a brake spring cover that seems like it is 394 style... WTF am I missing here???
I suppose I will just have to get out my whizzy wheel and modify this cover to work. I'll have to drill one of the screw holes in the correct location to boot. What gives? Anyone have a clue?
Here is a link to the 395 exploded part diagram. If you'll notice, the part in the diagram looks correct and is the shape of the part I need: http://www.partstree.com/parts/husqvarna/saws-chainsaw/395-husqvarna-chainsaw-2003-10/chain-brake/
But if you click on the part "details" you can see that this part clearly looks different and I can tell you is the 394 design and will fit my old 394 clutch cover. Note that the part is positioned upside down compared to how it is mounted on the clutch cover. This part has that sort of tail that extends downward after the angled bend. The part I need would be absent that and have a shorter distance between the two lower mounting screw holes: http://www.partstree.com/parts/husqvarna/parts/503720601/
I think Husky has some wires crossed with this particular part. Again, this part pulled from a brand new 395 that my dealer has on hand is shaped like my 394 part while looking nothing like the part in the diagrams and will not fit my new OEM 395 cover.
