- 9:39 AM
- Dec 30, 2015
- Brewster, NY
In fact, I may want to test a 660 that I have not tried different mufflers on yet, would be interesting.
Im glad I am considered a trusted saw tester on here by someone lol.Jeff, I can feel the difference in torque, which I'm sure would translate to cut times.
I'm sure the best running saws will have very open mufflers, as mine do, but it does not work on every saw.
If you want, I'll bring some mufflers for testing at the CT GTG, and I'll let your or Mason or Dan run them so no one cries foul.
Impressive results, but I would caution against applying them to all saws.
TM is expert at porting saws, and his saws need all the flow they can get.
I have a few saws that lost torque when I opened up the mufflers too much. Since I like to lean on a saw, I changed them back.
I believe that each saws has a sweet spot that will depend more on it's porting more than on any formula. (will depend on cylinder porting and ignition timing)
Also, I believe TM runs screens on all his ports??? (that would reduce flow about 50% compared to the unscreened ports some builders use?)
I put on my Motorcycle Helmet and lowered the face shield to prepare for the backlash!
I tend to agree, I’d think you’d want an average of at least 3 cuts rather than just oneAs far as the 461 being tested...most of the gains to be had with a muffler mod were realized with the first two ports. The additional ports may have helped a little, but the times are within the margin of error for the wood being cut. Just my opinion.
