EFSM
- 11:24 AM
- Apr 30, 2024
- Extreme southern IL
A customer brought in a CS-620 Echo that wasn't running right. After changing the weird fuel that was in it, it ran very well, but made a strange knocking noise at idle. So I pulled the muffler to inspect. I'm not sure how much longer the rings would have taken this. I had ported this saw a couple of years ago, when the original crankshaft bearings failed and I stuck the piston and cylinder onto a CS-600 crankcase with the old mega-advancing coil. Should I be worried about the cause of this or chalk it up to very high hours?
EDIT: I realized in looking back at sales history on the 620 piston that I replaced this one last year due to a broken crown. This coil advances far enough for the saw to rev 500-700 rpm's more than a 620 coil. Is that part of the problem?
![IMG_20241026_082111_090[1].jpg IMG_20241026_082111_090[1].jpg](https://opeforum.com/data/attachments/438/438246-4cfacd7f9c6ca4781ae55b0e684c67c6.jpg?hash=2kquhEtER-)
