Timberpro 6150
Rod73
New OPE Member
3:22 PM
UK
Hi I'm needing to pick your expert brains on an issue with a Timberpro 6150 20 inch chainsaw I have. I know the issue but just don't know how to fix it🫣🫣 it starts right up easy and will run well when you squeeze the throttle but then after a short while it cuts out, chased the issue to the tank not venting as if I loosen the cap a little it will run perfect, obviously not safe with the cap loose. Does any of you very clever people know where the vent is or how to fix this issue? I can't see an obvious white vent and the cap has no vent.....I'm beat with this one, thanks in advance
jacob j.
Only the weird
8:22 AM
Coastal Oregon
Have you tried searching online for an illustrated parts list? That would be the easiest way to figure out where the vent is.
Vents for the fuel tank are usually on top or on one side near the top.
