Throttle Shaft for Walbro WT465
Shane¹
10:41 AM
Kentucky
I don't have that exact carb but I have a carb that looks close maybe the throttle is the same it is a wte 6 and an injection carb that would work as long as it takes a kit? I think you would need the choke lever to go to the injection style too
Shane¹
10:41 AM
Kentucky
Looks like there is some aftermarket carb options. What is wrong with the throttle shaft? Is it worn?
Loony661
462’s 4-LIFE
9:41 AM
Winona County, MN
It was modified (along with the rest of the carb) when the saw was ported. The extra grinding on the shaft weakened and allowed it to bend, it happened the other day while I was using it - now the butterfly won’t close. I just want to replace the shaft with an OEM replacement if possible.
Shane¹
10:41 AM
Kentucky
That's a bummer.
Shane¹
10:41 AM
Kentucky
Looks like the wt374 is a McCulloch 3200 carburetor? Maybe @heimannm has something if we can find the McCulloch part number. Also found this carb on eBay might get you buy for nowMcCulloch carb
Loony661
462’s 4-LIFE
9:41 AM
Winona County, MN
