old_sir_henry
3:29 PM
Huge flywheel for such a small saw.
Agreed.
Some more pics:
Routing of the lines:
Chain brake internals:
Old style clutch:
New style clutch:
PS-39 and PS-390:
This PS-390 was the first saw I did a rebuild with. It still in my posession and one of the most frequently used saws I have. The PS-39 basically is identical to the PS-390, only different hoods.
Both share 39 ccm displacement and yield 2,3 HP DIN
Simondo
2:29 PM
UK
On the subject of unusual pull starts ....some first generation of the 109,110,111,115 had this tooth engaging ring ( 10 on the ipl) to the outside of the flywheel ..It didn't stay on the saws for long ! my 1986 Mk1 111 has it and you have to keep it free of crap or you get no connection.
old_sir_henry
3:29 PM
Very nice! Clean saws there. I wonder if the larger flywheel cleans the air of chips better?
I don't think so. I have had saws of this type as dirty as any you can find.
The ones in the fotos are clean becasue the shots were taken after I cleaned the saws ;)
And for the starter @Simondo metioned:
This is the flywheel:
and this is the corresponding part connected to the recoil:
When you pull the rope, the black ring protrudes towards the center of the machine and makes contact with the saw-tooth-shaped part of the flywheel.
Unfortunately the plastic teeth tend to wear off (as can be seen above) and after some time will no longer make a grip with the flywheel.
This was crap in first place and was replaced about 1987 or 88 with the well known ratchet mechanism still in use.
Black Dog Chainsaw
Mak-Crazy
9:29 AM
Indianola, IA
Agreed.
New style clutch:
I like the newer 3 shoe clutch pack... need to find a couple of those for my 390/401!
FYI those saws are pretty fun once modified! [emoji6]
old_sir_henry
3:29 PM
best thing is: They no longer strike the clutch-drum on idle and thus the typical idle jingling is gone
:clap:
