T.Roller
- 1:14 PM
- May 11, 2016
- Southeast, TN
Very true. What are you into tonight?Better late than never!
I feel for you brother. I don't see how yall can work on vehicles up there.Wheel bearing on a 99' s10. Flipping salt rusts everything up here. Had to cut some of the bolts. Gotta get new ones in the morning.
MhmI'm still a rookie myself. [emoji41]
QTLAHydrating before you drink ?
Lmao I decided to paint later. I'm gonna assemble it stock and run a couple tanks thru it. Then disassemble, port and paint.Weres the painting part? I was following this for painting tips dammit
Turns out to be a farmertech also just isn't markedI presume that 1st one is a stock Huztl??? If so, pretty close to what I guessed the #s are on my Huztl. Based on my measurements I guessed 95, 125, 83 (I know the 83 is correct as it is the same as my Cross Cylinder).
I have to get a worm gear and the air horn thingyTest cuts before tomorrow.![]()
And that's all over my head. Seems like I don't need to drop them much with the numbers where they are. I'll check squish tomorrow.Depends how far you drop them
Just enough to get to 190 or so is all you need.And that's all over my head. Seems like I don't need to drop them much with the numbers where they are. I'll check squish tomorrow.
10-4 thank you.Just enough to get to 190 or so is all you need.
The filter mount. It was missingair horn thingy ?
