1:03 PM
If it is a Great Lakes logger it’s be a highway truck, it’s weird to see logs piled sideways.
Not sure of its location. I was just paging Brett since he used to drive trucks and Michigan has frost rules so the truck have 37 axles.
They all look skinny so maybe their fence posts?
Skeans1
11:03 AM
Oregon
A lot of that wood up there is pulp not much else you can do with it. How much of the wood back there can you get more then a straight 17’ log out of?
chipper1
2:03 PM
Grand Rapids Mi
They haul them like that sometimes, usually eight-axle doubles though, they get around in tight spots a bit better.
Hey @chipper1 is this how your trucks roll in Michigan?
Probably an old picture would be my guess, but yes, 8-axles is normal in Michigan. The front trailer axle is usually a 9' spread so they can get more weight on them, and the back two axles are lift axles along with the 7th axle on the front(the one behind the spread axle), this way you are pivoting on 4 axles.
All axles no gaps? Imagine the scrub on the tires.
If you forget to lift your axles on a slow turn the scrub/roll of the tires will stall the truck and will back you up as far as you made it around the corner, if you have them down on a more open turn and you come in hot or have two much pressure on the spread axle the trailer will go in a straight line and the truck will jackknife.
Not logging, but..
Heres a truck I drove for a while.
This one I drove for a couple years then the boss said I was costing him to much money. He put a green guy in the truck(looked like the one behind my trailer), the guy had a light load and made it to the first wide turn and jack-knifed it, had to much pressure for the load in the spread axle lol.
Each one of the larger rounds is 17-18k, better have that load on there right before you hit the scale :cool:.
Screen Shot 2019-05-12 at 1.25.53 AM.png Screen Shot 2019-05-12 at 1.26.15 AM.png
Skeans1
11:03 AM
Oregon
Not logging, but..
View attachment 181178 View attachment 181179
One thing I’ve noticed is I don’t see any drops in the pictures of trucks from back there do you guys run them?
