ajschainsaws
Axes never run out of Gas
4:26 PM
South west UK
Mostly it’s a 4 speed stick and then. Range change and a splitter
But most where fuller 13 speeds then the 18speed came in as you say
Splitter in low
Now it’s mostly 12 speed auto with manual override
Some autos are quite jerky unless fully laden
ajschainsaws
4:26 PM
South west UK
Also a good set up over here was Eaton two speed axle
Paired too a fuller 5-speed gearbox or in some trucks
You could have a David brown 6-speed bos with a 2- speed axle
In the 80’s if you had a Perkins V8 or a Rolls 285
Hooked too this it would fly up the hills
There used too be alsorts going on bus axles on trucks
And when the 9- speed fuller came over there was a few that
Put 2-speed axle as well DOT had a field day on the freeway catching trucks doing 75+
