Stihl workshop manuals
Adam G
Zigzag failures +4
10:01 PM
USA Charlotte
Im in need of an IPL For a Stihl MS440.
TIA,
Adam
Deezsaw6
Active OPE Member
7:01 PM
Washington
Ive looked and didnt find a IPl for a stihl HT81T? And i sure could use one! Thanks
elio.rsvr
New OPE Member
4:01 AM
Italy
Hi everybody
I'm Elio from Italy
in first I have to escuse me for my bad english
i am looking for service manual for my new MS194T
anybody can help me?
markds2
2:01 PM
Nelson, New Zealand
Hello Ray, would you have a parts list and service manual for the Stihl 042? Also any service bulletins if you have them. Much appreciated.
Wonkydonkey
Plastic member
3:01 AM
Sussex, UK.
Hi Ray, FSA 56 ipl ?
I saw a friend today. He was complaining about not having any luck with trimmers 🙄
So he got a battery one and still having problems, I had a quick look and said I think you got bearing problems on the motor head
So would you have a FSA 56 manual/ipl Just so I know what I will be getting my self into and maybe I could order some bearing other than the stihl overpriced bearings 😉
ray benson
9:01 PM
nw indiana
Check your inbox
Boogerman61*
7:01 PM
England
If anybody still needs a parts, repair or user manual let me know what you are looking for. I have quiet a few.
ray benson
9:01 PM
nw indiana
Wonder if you have run across an updated ipl or service bulletin in regards to the new design 462.
462 cm design changes - piston cylinder
April 2021 was the change - at serial # 190015190
All I have seen is this
Boogerman61*
7:01 PM
England
Guys,
Does anyone have the IPL and Manual for MS261 and MS261CM. I would like to see the differences and the retrofit to CM if it can be done.
Thanks
CHAIN SAW FEATURE DESIGNATIONS
C Features
B= QCA (Quick Chain Adjuster)
E= Easy2Start™
i= Electronic fuel injection
M = STIHL M-Tronic™
O = Oil sensor
"M" is for
STIHL M-Tronic™ (M): Innovative, microprocessor
controlled engine management system adjusts the engine
to compensate for changes in operating conditions, such
as temperature, elevation, fuel quality, and dirty air filter
to optimize engine performance. Microprocessor measures
RPMs and adjusts fuel accordingly (richer or leaner).
Electronic ignition timing and fuel metering provides quick
acceleration. Simplified starting procedure reduces the
chance of flooding.
