Jmac460
Active OPE Member
- 12:30 PM
- Feb 2, 2019
- New Hampshire
FS91R manual and Ipl anyone? Thank you!
Check your inboxFS91R manual and Ipl anyone? Thank you!
Check your inboxHello. Do you happen to have a workshop manual for BR 350 backpack blower? Thanks!
Check your inboxHello @ray benson
Any TS460 Concrete Saw literature on file?
Check your inboxDoes anyone have access to a manual for a ms462 Arctic? Specifically the heated components.
Check your inboxDo you happen to have KM55R Kombi service manual and IPL?
Thanks!
Check your inboxNeed 201tc ipl
Check your inbox
That is the service manual that Stihl uses on the 360. Here is a tech bulletin explaining that the 036 and 036qs were renamed to 360 and 360c .In this post https://opeforum.com/threads/stihl-workshop-manuals.1112/#post-50597 it lists the ms360 but when I open that pdf (
ms 360 360c.PDF) it's for STIHL 034, 036, 036 QS which is not identical to the 360. Does anyone have a workshop manual specific to the 360?
Ah ok. I noticed that the carb vent is different than the one in the pdf so I wasn’t sure if any of the information was correct. I’m trying to troubleshoot strange carb issues and wanted to definitively know what the “default” needle settings were so I had a baseline. Looks lik 1 turn out from that pdf.That is the service manual that Stihl uses on the 360. Here is a tech bulletin explaining that the 036 and 036qs were renamed to 360 and 360c .
