Jimmy in NC
- 1:22 PM
- Dec 23, 2015
- North Carolina
I have read several complaints about the Asian chain adjusters for the 066 kit saws. I also have used them from HL and @Definitive Dave before with no issue. I put my "Jim Zing" 066 together and the adjuster seemed to be gritty but OK. Test run was short lived, situation fixed, and back to test running. I realized the adjuster would go back but not forward. Hmmm.. I happened to have another kit saw (MS360) there that the adjuster worked super smooth on so I popped it apart. I then realized I have an OEM 036 there and apart it came. I like to KNOW what causes the issues as opposed to just "chuck it in the f&*k it bucket" and move on.
Through some playing around what I found was the gears were not meshing deep enough to maintain engagement causing a gear bind. Turning one way causes the gears to pull into each other and the opposite direction pushes apart.
What I found was very interesting. I apologize I forgot to get pictures but I took dimensions of the "big gear" and the pinion.
OEM: 0.600" & 0.328"
Farmer Tech #1: 0.642" & 0.312"
Farmer Tech #2: 0.626" # 0.312"
Adjuster #2 is the one that does not work and it's pretty clear why, the main gear is undersized. 0.016" is probably most of the engagement there is on these things. Clearly the Asian parts have a bit different gear ratio than the OEM. I'm OK with it if it will work.
Next question and this is for @Gentleman mainly: The pictures on the HL site show a shiny finish on the adjuster kit. The two adjusters that come in the saw kits have a matte black / black oxide finish. Are these just differences in stock photos or are the stand alone adjusters from a different vendor or of a different grade than the kit components?
I'm not griping about these kit saws. They are not 100% bolt together and go.. I knew that. They are fun and working through these issues is part of the fun for me at least. I also am curious on these adjusters as the local crews I help maintain equipment for, destroy plenty of these adjusters. I find most of the time a "groundie" will try to replace a chain with out backing the adjuster off and tries to force the bar on with the bar nuts and bends the left handed screw/pinion OR they try to adjust bar tension with out loosening the bar nuts. Either way I see these torn up often and would like to keep a few on hand. I do NOT want to keep some on hand if something has changed or if they are VERY hit or miss.
Constructive feed back appreciated. If you've had 3 out of the bag be junk... say it. If you have used 10 and only 1 bad.. let me know. I'm curious.
