Jmac460
Active OPE Member
- 6:22 AM
- Feb 2, 2019
- New Hampshire
Looking for some help, are all ms661 cylinders the same? M-tronic vs non? TIA!
I figured either you or @Woodpecker wood know the answer.
how the hell would I know? Ask blue balls
Nic only knows anal beads, dent pullers, and plumbing van seats in that order. I bet waaandy would know @MastermindI figured either you or @Woodpecker wood know the answer.
What exactly is your query? They all have the same mounting bolt pattern, front fed transfers and have an intake boot. Timing varies ever so slightly across the board.Looking for some help, are all ms661 cylinders the same? M-tronic vs non? TIA!
I’m not a Stihl dealer and I have a customer who needs a top end kit for a 661c-m. I guess I’m looking for the correct part number.What exactly is your query? They all have the same mounting bolt pattern, front fed transfers and have an intake boot. Timing varies ever so slightly across the board.
Weakyou shared the knowledge of the first two and I didn’t ask.
Weak
Thank you- that’s the number I ordered. I appreciate your help.P&C kit - 1144 020 1202
