popopboat
- 5:03 PM
- Sep 17, 2019
- Croatia
Once again a post about my MS650 !
In my last thread ( https://opeforum.com/threads/stihl-ms650-new-mysterious-behaviour.30751/#post-1582731 ), I described how my MS650 started acting up when hot, with the PTO bearing the culprit in the end.
I replaced it with a new OEM NTN bearing from the dealer (replaced oil seals also with new OEM), after what i used it for maybe an hour or so and it was resting on the shelf since then.
Today, after some cutting, the issue resurfaced. After just a few cuts, the saw started behaving erratically again. I checked the bearing, and sure enough, there was already some slight play.
Why? What causes this? Has anyone encountered this ever?
To be clear :
- Im letting the saw doing the work, rarely use dogs.
- Chain is sharp, depth gauge is set to 0.6mm (0.025" ) with a grinder.
- Bar is smooth and not disfigured.
- Firstly used Castrol Power 1 Racing at 40:1 (or even more), tried switching to oil that local forestry used.
- Carb is set on rich side.
- Clutch drum, clutch, clutch bearing and crankshaft are OEM in very good condition.
- Saw is slightly "ported", widened and polished but port timings were not touched.
- Mild muffler mod.
- Ignition timing is stock.
- Bearing is NOT loose on crankshaft nor it spun in the crankcase.
Id really appreciate if someone could help me as im not planning to replace the saw.
To be clear :
- Mild muffler mod.
