Stihl MS170 Chain
bobsculley
New OPE Member
12:17 PM
Italy
I recently bought a new chain for my MS170. I got it on Amazon. The part number is 36360001640. Other info on the label is 50M 3/8 1.3.
The chain is the correct size, but the followers fit too tightly into the groove in the guide bar. When installed the chain won't move. This is not an issue with the guide bar as the old chain worked, fine.
What is the correct part number for the MS170 chain? Any recommend sources?
Thanks
Chainmale
10:17 PM
Tasman New Zealand
Chain width is measured in "gauge". 1.3mm is .050 ms170 standard is .043 or 0.9mm which is why it's tight in the bar groove
irhunter
6:17 AM
Maine
Thanks
Here's the deal. Most bars are marked with the required chain pitch, gauge, and the number of drivers. You need all three numbers, off the bar, to correctly order chain.
In the event the bar is unmarked, here is how to determine the three numbers:
As far as where to buy...nothing wrong with Amazon, if you confirm you are getting the correct chain. For a few bucks more, a Stihl dealer will sell you a chain. Take the saw in with you when buying your first chain.
Roy
hacskaroly
2100 Fanclub Member
3:17 AM
Northern Idaho, Ehh
Typically the MS 170 comes with a 16" inch bar, the chain size for it should be 3/8 picco (pitch), .043 (gauge) and 55 drivers.
The part number you should need will be: 3610 005 0055 - 61PMM3
* 6 - 3/8 picco (pitch)
* 1 - .043 gauge
* P - Picco
* M - Micro
* M - Mini
* 3 - Single Hump Tie Strap
1701107687237.png (Here is the box, red outlines the pitch, gauge and drivers, blue outlines the type chain and part number)
Typically the side of your bar will have a stamp or laser engraving of its information and will typically list the pitch, gauge and number of drivers along with the part number.
There are 3/8 p, .050 (gauge) 55 driver chain that is available, but those are typically used for some of the Stihl pole saws.
